Hello!
Donwsizing i sortementet, solgt alle boblene, har noe fine deler for slag, selges som et komplett kit:
EFI bygget med utgangspunkt i Tysk hardware
Megasquirt MS2 V3
Relayboard
Quadspark
Coil on plug
Innovate Lambdasonde med instrument
osv
100psi pressure - plus wiring, added circuit 1 $90,00 $90,00
Used pulley - Boost pulley and sensor bracket 1 $100,00 $100,00
Delsum $190,00
Frakt og administrasjon $11,00
PayPal (2,9%) $5,51
Sum $206,51 USD
German based EFI kit - Complete kit excluding air filter element 1 $1 600,00 $1 600,00*
Relay Board - w/fuses and power wires 1 $90,00 $90,00*
Relay Cable - All positions filled 1 $75,00 $75,00*
Wire bundle - 12 foot wire bundle included 1 $0,00 $0,00
Fuel injectors 24# - Standard injectors 1 $0,00 $0,00
Fuel pump kit Walbo 255lph - Kit standard pump 1 $0,00 $0,00
ECU upgrade - V2.2 ---> V3 Main Board 1 $74,95 $74,95*
ECU upgrade - MS1--->MS2 processor upgrade 1 $100,00 $100,00*
Map Daddy - 4bar w/ barometric correction 1 $64,95 $64,95*
Quad Spark - For driving COP's 1 $89,00 $89,00*
COP ignition coil - Short for type1 4 $27,50 $110,00*
COP ignition coil - Connector 4 $5,50 $22,00*
COP coil brackets - mounting brackets 2 $8,00 $16,00*
VR bracket - VR sensor bracket type 1 1 $9,95 $9,95*
VR sensor - Hidden VR sensor for type 1 1 $49,95 $49,95*
Machining - Machining of a type 1 pulley for hidden trigger wheel 1 $40,00 $40,00*
3 pin Delphi VR connector - For VR sensor, watherproof 1 $8,00 $8,00*
Steel Pulley - For trigger wheel 1 $75,00 $75,00*
Trigger wheel hidden - Hidden trigger wheel for type steel pulley 1 $40,00 $40,00*
Distributor Plug - To fill distributor hole 1 $20,00 $20,00*
LC-1 Wideband - With red dash gauge 1 $205,00 $205,00*
Air Filter - Standard cone filter element 1 $20,00 $20,00*
Delsum $2 709,80
Frakt og administrasjon $115,00
PayPal (2,9%) $78,59
Sum $2 903,39 USD
Totalen er 3.100USD + MVA
Gi Bud
http://thedubshop.goodsie.com/embed/ger ... 0a5f176446
Megasquirt EFI, The Dub Shop German kit
- EFIGermankit.jpg (65.28 KiB) Viewed 1708 times
Sv: Megasquirt EFI, The Dub Shop German kit
Ble dette solgt, Bjørn...?
Jeg snakka med Knasten, han har allerede deler på plass til min oxy. Så da utgår min interesse her.
Den er godSolan wrote: Jeg snakka med Knasten, han har allerede deler på plass til min oxy. Så da utgår min interesse her.
