Page 18 of 29
Posted: Wed Mar 25, 2009 6:18 pm
by RZR Andy
Blir jo skikkelig strøken den der Pål!
Posted: Mon Mar 30, 2009 11:58 pm
by erika
Dørhengsel-pinne-fjerne-verktøy. Kjekt å ha. Til låns for de som kommer og leverer tilbake etterpå!
Posted: Tue Mar 31, 2009 12:02 am
by RZR Andy
Kult, det virker jo som et stykke supert maskineri det der. Kraft gang arm komprimert ned i et hendig lite verktøy..
Posted: Tue Mar 31, 2009 3:56 pm
Oi!  :o :o
Er dette verktøyet også egna til å fjerne dørbolter på splittbuss?
Posted: Tue Mar 31, 2009 5:43 pm
by erika
Instruksjonene som følger med tilsier det, men det var en kommentar der som jeg ikke helt husker i farten. Kom gjerne innom på Hop.
Posted: Wed Apr 01, 2009 12:40 am
by RZR Andy
"You will NOT have to remove a bus bumper or the running boards from a beetle to remove the lower door hinge pin.
This tool will not remove a bus mirror arm but it will remove the mirror arm that is usually used with an elephant ear mirror. I had been asked by a couple people to make a "bus only" tool that would remove the mirror arm and cab door hinges. I made a prototype for this but it wasn't successful at all. The problem is that there is not enough surface area for the head of the tool to seat against the top of the hinge. The base of the mirror arm is nearly as wide as the hinge itself. So I have stuck with what the tool does best and that is both beetle and bus cab door hinge pins. I also have been told that the original VW hinge tools will not remove the mirror arms either.
I have tested this tool out on quite a few beetle and bus hinges and it has worked great. The tool body is made of solid steel with a hardened pivot pin. The threaded bolt is also made of hardened tool steel with a polished end for extended tool life. The tool comes with a complete set of hardened pusher pins. "
http://www.thesamba.com/vw/classifieds/ ... ?id=522550
Posted: Wed Apr 01, 2009 1:25 am
Takker, Andre,
Nå har jeg ikke prøvd det ennå, men jeg innbiller meg jo at det skal gå fint hvis jeg sliper eller kutter vekk den lille flensen nederst på den gamle speilarmen (som jeg skal ha vekk), da skal det vel bare være å feste verktøyet og trykke "splinten" oppover?
Skal gjøre et forsøk på abc i morra onsdag, hvis ikke Vikør (mot formodning) skulle ha henta Bløygen til Norheimsund.
Posted: Sun Apr 12, 2009 1:36 pm
by hans
et par baklys til 58'n samt en aggressiv kam i bobleplast
har enda et par baklys (snowflakes) - men de er i dårlig stand og er mer som reserver å anse i tilfelle uhell
Posted: Tue Apr 21, 2009 5:19 pm
by T-1
nytt ratt til bayen handla fra berger på vwnorge  ;D digger gaver i posten :P
Posted: Tue Apr 21, 2009 11:55 pm
by Moshe
Fikk en fabrikkny Hazet-2568 by US-mail... :thup
Posted: Wed Apr 22, 2009 12:16 am
T-1 wrote: nytt ratt til bayen handla fra berger på vwnorge  ;D digger gaver i posten :P
ehhh...gaver?
Posted: Wed Apr 22, 2009 8:55 am
by Jon T
Moshe wrote: Fikk en fabrikkny Hazet-2568 by US-mail... :thup
Ventil justering?
Posted: Wed Apr 22, 2009 1:19 pm
by Moshe
Ventil justering?
Jupp - jupp.... ;D
Posted: Wed Apr 22, 2009 1:26 pm
Ventiljustering gjør vi vanlige dødelige (og fattige) med skrutrekker og 13mm fastnøkkel ;D
Posted: Wed Apr 22, 2009 1:32 pm
by Jon T
Solan wrote: Ventiljustering gjør vi vanlige dødelige (og fattige) med skrutrekker og 13mm fastnøkkel ;D
Skulle ønske jeg også var udødelig...
